So I have a boat on a rual lake. I do not have access to any waste pump out stations. When I have tried to get someone to pump out - its a disaster because they don't normally do that. Oh, wait - here is the final nail - my head only had a 5 gallon holding tank.
Yep, a PITA. So here is what I have resolved myself to ..... I installed PVC pipe and fittings that go below deck and back above deck to a macerator pump. I basically use that pump to pump out the small tank into a 5 gallon bucket and then dispose of that at a marine porta-pot. Yuck - but you gotta do what you gotta do.
So here is the problem I need help on. The macerator is self priming but only when liquid is present. The fact that the plumbing goes below deck and comes back above pretty much ensures that the pump is only exposed to air when I hit the pump button. So I am having to prime with water every time to get the pump to prime.
The steam is mostly water with limited solids. I have thought about installing valves to hold the liquid head to improve priming. Is there a different pump or solution that I should be thinking about?? Be nice to just pump and be done - this is yucky enough to start without having to prime. Any help is appreciated.
