Unfortunately I tend to agree with Pascal's observation. My 260 Sundacer is the exception as are the 240 Sundancer, the 270 Amberjack, and 280 Sundancer with single engines. All of those cruisers even when equipped with Gennies are very easy to work on. As soon as you get into the twin engine v-drive cruisers, there are issues with "packaging" on many models. If you have outdrives, it helps somewhat from what I have seen because the engines are not turned around and shoved up against the transom as they are on many of the V-Drives. But if you think the cruisers are bad, most of the Sport Boat's in Sea Ray's line up are extremely hard to work on. Try changing the impeller in a Sea Water pump on a 220 or 240 Sundeck as an example and you will see what I mean. Without removing panels or standing on your head you can't even reach them.
The whole issue of engine (room) accessibilty seems to take a back seat to style or interior room which makes a lot of the regular DIY jobs that much more difficult in many of their models.
