- Sep 16, 2003
- 12212
- 12,219
Digital charts are all based on the same data. The accuracy of either type is just bad, a couple of feet if you re lucky, on average.
Yes a sounder will only tell you what's under the boat but if you are careful that is usually enough warning if you are going slow enough. Personally unless I have been thru before I do not run on plane with less than 4' under the wheels Less than 3' and it s idle speed. 2' it s in and out of gear and at 1' it is reverse.
I ve lost count of the number of times on the icw where the bottom came up and and I had to back out and try a different track 30' on either side of a problem spot.
And have you noticed how for many inlets the depths are not charted at all? How can you rely on charts that don't show the depths
