I have a 98 Yamaha 90hp 2 stroke, salt water edition. When I first get out on the water the motor will only go up to 2000 rpm in forward, regardless of how much throttle I give it. It will go all the way in neutral and reverse. After about 20 minutes of driving like this it sputters and surges a couple times and then runs like normal. For the rest of the day it will run like normal, even after being turned off for a while. But at the beginning of each day it goes through this process. This all began after I had a prop strike. It jarred the outboard pretty hard. I replaced the prop afterwards.
Here’s what I’ve done so far:
Cleaned the carbs completely
New fuel pump
New filters
New plugs
New Prime Start
New fuel lines and primer bulb
New fuel pump
New filters
New plugs
New Prime Start
