Thanks. So there is a nut behind the flange that holds the seal in, not talking about the nut that holds the flange on the spline/shaft?
My understanding is that the seal goes on the spline and you use silicone sealant to seal it to the spline. I guess that means the whole seal spins with the shaft as opposed to the shaft running through the seal?
When you say "drove" the seal in, what do you mean? I would be concerned about damaging it and having it leak if not handled carefully.
I was also told that these rarely leak unless you have an alignment issue. Alignment was checked last year and was fine. If there is an alignment issue, the back of the flange will be scored and need to be replaced.
