Hello;
2007 3.0L Mercruiser I/O. Top cooling hose came off and because of radio on and in the process of passing some boats I did not hear the high temp alarm.
Engine died and I coasted to the dock. Got a tow back to ramp. Engine ran maybe a minute or two with alarm on, not really sure.
Found out the hose clamp corroded (stainless steel?, yea right)and broke, so I replaced and started engine in driveway. Engine appeared to run just fine. Oil pressure OK, cooling temp went up and then stabilized at normal running temp. All looks good.
Anything hidden that I should be concerned about that might have been mucked up when it was running w/o cooling for a minute or two?
