Paint my bottom?
Thompson gunr
OK.. I am sure that got some interest in ways other than I mean. I have a Thompson 245 Carrera that I am considering leaving in the water all next year. I have been trailering it this last past season. The Previous Owner said he left it in the water on Lake Erie all year. The bottom has never had bottom paint as far as I can see. Should I paint it? What is the advantage to painting? Our old 32' DrifterCruz had bottom paint and so I cleaned it and repainted every other year. Of course the old 42' Chris Craft wood boat had bottom paint. But if it is not already painted am I gaining anything by doing it now? Easier cleaning? Keeping things from growing on the hull which helps mileage? BTW, I boat in fresh water (Ohio river). Sorry to be so long winded. Thanks. Looking forward to the responses.
I've done it both ways. My experience is from Lake Michigan so that's probably a bit cleaner and colder. Unpainted requires an acid wash at the end of the season to get all the algae and stain off. It's a nasty job. I did it a couple times and then left it up to the professionals after that and finally painted the hull. Painted hull basically requires a power wash and you're good to go. My current paint job has lasted 6 years and will require a new application before launching next spring.
So a power wash is not enough to get the algae off? What are the thoughts about doing the original painting yourself? I am not sure about marking the waterline. Should the first time be left to a pro then follow up with my own painting later? Every boat I ever had was already painted before I started so marking the waterline was already done for me. I guess I could put it in the water and make a measurement of the waterline on the bow and transom then mark a straight line between these two points with my laser level. Is there an easier method? What about differences in loading? How much above the actual water line should I bring the bottom paint? Thanks!
Let the pros do it the first time. If the hull is not properly cleaned and prepped, the paint will not adhere properly. If the pros do it, it is more like to be done correctly and if they screw it up, you have recourse.
And yes it is worth it to get it painted before leaving it in the water 24/7.
Any idea what I should expect to pay for this work? I don't mind paying if this is the right thing to do but I don't want to get taken either. Just want it done right. The boat is a 25' with an 8' beam if that helps. Thanks.
A powerwash may get the algae off depending on the quality of the hull polish at the beginning of the season, but there will be a significant stain left behind. With my experience, kind of a brown color probably from the tannic acid in the northern streams. An acid wash was all that would attack it. When I did the job myself, I used an industrial drain cleaner (mostly if not entirely sulfuric acid). I'm sure it broke every environmental rule in the book. After that "bath" I had the job done professionally. As the previous post suggests, get the bottom painted by a knowledgeable firm. There's much more to the job than a coat of paint and proper prep of the hull is imperative.
I guess it is that I am a stubborn "do it yourselfer" but I should start learning from those who have "been there done that". I always painted the hull of my other boats but like was said earlier, if it isn't done right it will not be worth the $ for the materials. Speaking of which, what should I be looking for as far as bottom paint goes? (Brand, ingredients etc so I know when I walk in what to ask for.) Usually if you walk in and give the appearance like you know what you are talking about they are less likely to take you to the cleaners. Thanks.
Actually your "scum line" is the best waterline indicator for your painting then I would add two inches.
Unless you are delivering a dirty boat to the painter he is just guessing as well.
I was wondering if you had considered Tattoo [:-bigeyes2]
Anyway, as far as DIY is concerned, make sure you prep with a strong wax remover. Then you need to rough up the surface with something like 80 grit sandpaper. Next clean it off again.
Being that the boat has been in the water quite a bit already I would say the release wax is long gone and that is probably the biggest source of new boat bottom paint failures.
Given the price per gallon yer goin' to the cleaners regardless. I use Interlux Micron CSC and get good results in the Hudson River so long as it is pressure washed at the end of each season.
Like Gary said, add a couple inches to your scum line. there is no reason you can't do this yourself. A friend did his this year using the sandless primer with great reults. Good paint adhesion at the end of the season and a clean bottom.
Thanks all. I have already thoroughly cleaned the hull in preparation for it's winter hibernation. I may be able to still see a slight bit of the scum line but it is very light. Thanks. I will check with the local fiberglass boat guy and see what he uses and charges. He is less than 2 miles from my shop where the boat is stored.
