Originally posted by Sandy
This is for a 153 c.i./ 2.5L 120 ho engine , yes?
I suggest you check the distributor shaft and bearing by holding the rotor on the shaft and try moving it directly side to side in all directions ( not rotating.)If there is "play" there, the bearing is warn, and it would be best to replace the whole distributor.
Another clue indicating dist, shaft and bearing wear is a "nervous" tach gauge needle at idle.
If the dist. tests OK, the Pertronix Ignitor II with the RED module is definitely worth the little extra cost over the original (black module) Ignitor conversion kit .
That's because the original black version will burn out if the ignition switch is left on to power other things &/or perform electrical tests, but the Ignitor II does not have that vulnerability.
However, if the distributor is worn , IMO your best best bet would be to replace it with the really good Delco Voyager EST kits with new all- electronic advance distributor, matching coil and quality plug & coil cables.
http://store.enginepartscenter.com/mercruiser-470470r485488r-omc-100110120-91146a-45111-p2478.aspx
https://www.michiganmotorz.com/3-0l-delco-voyager-est-marine-electronic-distributor-kit
Good luck.
