FWIW, I highly recommend taking them to a scan shop and watching them perform the free simple scan so you can easily comprehend what the prinout graphics & data represent and know it's accurate. Have them explain the results printout you keep & service options for you to consider. The shop I've been going to in RI is very friendly and surprisingly happy to answer & expand upon all my questions, practical & theoretical .
I believe it's worth making sure your props conform to ISO class 1 specs ( though others may be satisfied with ISO 2 at slightly lower tuning cost), and the bar graphs nicely show any deviation from this at any of several radius points of each & all blades, as well as not-uncommon average pitch differences between port & stbd wheels. These can be corrected to balance & match the pair much better than could be done with the no-scan old method. The preliminary printout you get will list which minimum ISO spec your props presently conform to in their pre-service condition. Make sure you confirm to what ISO class spec your props would be tuned to if they quote you a price. Class S tuning is generally pretty pricey & the difference between S and Class 1 is probably not noticeable except on larger or very high-end prop systems, but I'm convinced 've felt the difference between class 1 and class 2 condition of my own 17" 3 blade props.
If your props aren't matched, the engines bear uneven loads resulting in possible fuel usage and other annoying mysteries. Out of balance can cause vibration and cutlass or other bearing and/or seal wear. Either condition reduces propulsion efficiency.
Even if they look great, the contact with pot buoys or other flotsam and jetsam or brief, even unnoticed, soft groundings in shallow channels, etc., most all of us encounter at some point in the season will effect the efficiency of the prop and a lot of new props are unbalanced right out of the box . Few pairs are matched right out of the box unless specifically ordered matched. Even if you decline the prop work, if the scan is free ( & there are some shops where it isn't- call 1st), why not have them scanned unless there just isn't a scan shop anywhere at all near you?
I had mine scanned and tuned to ISO class 1 last year and Prop-Scanned again about a month ago. Port prop was still just as the "after service" scan showed last year but the stbd was down to mid ISO 2 so I left that to be matched to the new scan record of the port stored in their computer file . If I needed to replace one or both props , I could call up the prop-scan shop and have them tune the one or a new set to be identical to the tuned specs on file if desired. Nice.
A little more info:
http://www.blackdogprops.com/2.html
http://www.blackdogprops.com/6.html
