- Jan 1, 2000
- 3238
- 4,831
tcijoe
Thanks to advertising, we ( as a group ) seem to have lost sight of what exactly takes place in modern devices. In this case ( rec. marine radar ) the catch is "time". Or rather using the correct unit of measurement. That 4kw radar certainly does produce a microwave signal "at the rate of 4000 watts per second". The "catch" is that it does not run continuously, but that it pulses ( I'm not going to check the manual, so what follows is approximate ) about 180 times per full revolution, with each pulse only a few nanoseconds long. Ah, but what is a nanosecond? It is one one billionth of a second. So it becomes obvious that even a prolonged exposure to a rec marine radar will produce far, far less than 4kw ( watts, total, not watt-seconds ) of energy transfer. SO, the truth is that, over a period of time, very little energy is radiated. So little that it won't heat much of anything ( the basis of the risk ). In contrast, the microwave oven that you warm you Starbucks in radiates continuously and that 1600 watt micro will dump more energy into that poor unsuspecting cup of coffee in a few seconds than your marine radar produces in total over a period of a year.
The use of microwaves as a heating device was noticed when the chocolate bar in the engineers pocket melted during a test...
