RECYCLE GRAY WATER TO WAST WATER
PEW
RECYCLE YOU WATTER WHEN DOING YOUR DISHES / BRUSHIG YOUR TEETH HAVE YOUR GRAY WATTER DRAIN IN TO A SMALL HOLDIND TANK PLUMB THE TANK WITH A WASH DOWN PUMP THEY ARE CHEEP TO BUY
INSTALL A SMALL PRESURE BLATTER IN TO THE LINE THAT WILL GO TO THE TOILET THEN YOU CAN USE THE GRAY WATTER TO FLUSH WITH AND NO DISCHARGE OF GRAY WATER THIS WILL KEEP THE WAST WATTER SEPERAT FROME FRESH WATTER AND IF YOU RUN OUT OF WATER TO FLUSH WITH THEN TURN ON THE THE BATH ROOM SINK TO DRAIN IN TO THE GRAY WATTER HOLDING TANK AND FLUSH THE TOILET INTO THE WAST TANK
