I removed a foamed in place (FIP) tank from a 23' Formula many years ago. I don't envy you. The biggest issue is the foam doesn't so much adhere to the tank, as it creates a vacuum as it cures.
First and foremost, SAFETY!!! If you can get to the fuel sending unit, remove it and gas free the tank. Fill it with water or let it air out for several days.
I would recommend removing as much foam as possible from around the sides with an electric carving knife. Wear gloves. That stuff sticks to everything!!
Get a PVC Cable Saw. Depending in the length you require, you may need two. If you do need two, cut one end off each saw and join the two with a square knot.
If you have a helper, and if the tank has a lip, use something as a lever and have the helper apply upward pressure on the tank via the lever as you cut it with the cable saw. It's painful because too much pressure and your lever breaks but not enough and your efforts get halted. But once the vacuum is released the tank will darn near pop out on it's own. It took me 2 days to get an 85 gallon tank out of my Formula. Actually, it took me 30 minutes and a couple of broken shovels (leverage).... It took two days to figure it out.
HTH.
