I'm replacing the old plastic scuppers and the floor drains on the port and starboard sides of my boat with new stainless types.
I'm deciding which sealant to use, 3M 4200 or 5200.
From what I am reading the 4200 isn't permanent while the 5200 is.
Of the two, only the 5200 is claimed to be good above and below the waterline.
While I wouldn't expect to have to replace this hardware again, I like the flexibility if I ever had to for some reason.
The floor drains will get wet when it is raining or during wash downs but shouldn't be submerged in water often but if leaves clog the drain, they could be.
The transom scuppers are at the waterline, so they could get submerged when the boat is in the water (I trailer the boat).
Therefore, the 4200 might be good enough and if I ever had to remove the drain or scuppers, it will easier to deal with if I use 4200.
So is 4200 good enough, or should I stick with the 5200 which is the one that is good above or below the waterline?
(I am also replacing the both of the old 1- 1/2" inside diameter hose and using all new SS clamps.)
Thanks!
Thanks!
