- Jun 8, 2004
- 13885
- 2,978
I had a problem with one of our Vacuflush heads this past week.
The Vac pump would not turn on unless I manually move the pressure switch and then it would only work for a short while, the system would flush once and then I needed to move the switch again.
Oh Sh!t, I need a $150.+ switch!
Well for the heck of it I took the pump apart to look at the duck bills, my S-Series vacuum pumps use 4 duckbills, and found the two outboard duckbills inverted – they were facing the opposite direction from the way they were installed.
I got new duckbills(from boatfix), installed them – the right way- and all is working fine
Has this happened to anyone and do you know what caused the outboard duckbills to get inverted?
