- Aug 5, 2008
- 30499
- 6,405
I have two separate breaker for each pump on board I have a locking breaker on each of the float switch circuits and then a standard breaker for each of the manual switch circuits the pump I just replace had an internal issue causing it to draw way to much power I cut the wiring right at the pump and spliced the new pump to the wires at this point now everything is working perfectly. This said it does have a long output hose that does draw a bit of water back in when it turns off. I have a check valve which I can install to help prevent this but I don't think there is enough water to be the issue. The new pump runs without an issue I can run it at length and it doesn't throw the breaker. I need to install weather stripping to help prevent the excess water intrusion this should help a bit as well! Maybe I will stop at the auto parts store today.
