Sure, it's used below the waterline most of the time. However, if the through-hull is also below the waterline, your insurance man will want you to install a vented loop, to protect the boat from sinking if a fitting were to break, etc. The vented loop should be 4-6" above the waterline at the greatest anticipated angle of heel, and should be as close to the through-hull as possible.
