Side window leak sliding windows
Wintersux
I have a 320 94 model voyager. The head sliding side window seems to always let in a little water after every rain. Is there a window drain that is plugged or do I need a new track for the window. No other side windows are leaking. This is the front starboard side of the boat cabin. It is not in the shower portion. It is the first slider on the stbd side.
there are drains in the track...small plastic doodads with 3 screws cover a drain slot on the outside of the window frame, take this off, clean the slot and reinstall...you should be good.
if that doesent work remove the bottom mounting screws inside the track and reseal.
Thanks! I am just amazed that water shows up in the floor of the head after a rain. The tracks are dirty from the winter. I appreciate all the info.
You are all a great help.
There are no small plastic do-dads on the outside of the window frame. There are some slots in the outside lower frame. I cleaned them up. There is a bolt that is under the coaming in the head. If I seal it on the inside won't the coring get soaked?? It sure is cored under the window frame.
