- Jun 25, 2001
- 5084
- 67
Hello, I have 2016 Mercruiser 4.5l 250 Engine with an alpha 1 and just recently the speedometer stopped working. I did check the port hole on the outdrive and poked around with a small drill bit as I thought it was clogged by a spider web but that did not help. I then proceeded to the speedometer at the helm and pulled the tubing and blew air through it with my compressor and did notice bubbles coming out the outdrive, however that still did not resolve the speedometer issue. Does anyone have suggestions on what to check or test next.
Thank you
Thank you
