I recently bought a 1968 Thompson 21' cuddy with a model 1967 SternDrive and noticed something this weekend that hadn't happened before:
I had the boat at home just to run through some things before taking it out the next morning. When I started the motor up I almost immediately noticed a "growling" noise that seemed to come from the upper portion of the sterndrive.
I noticed that both ball gears look sheared a little as if it had been ran with the drive lifted up (that's a no-no, right?).
Also, I checked the BRP Parts Catalog I found here (great help, BTW) and I would guess that there are problems with the gears and/or bearings related to the following parts:
DRIVESHAFT & BALL GEAR
PINION GEAR & BEARING
SHAFT AND BEARING
Now, I'm fairly mechanically inclined but am new to boats. It seems that there are only four bolts holding the entire assembly to the back of the boat. I would imagine with some strong help and attention to detail we could pull the sterndrive off, get at the parts and have it mounted back up relatively quickly. Am I correct?
One last thing...there is an electrical wire running through the back of the boat down into the drive. It doesn't seem to have any slack on it. I'm sure I'll need to unhook it so as not to rip it out, but what is it for? Is the "transmission" simply electric and this is where the signal to switch in/out of gear comes from?
I'm new and may get some of the terms wrong. I appreciate any advice I can get.
EDIT: I will also post this on iBoats when they get back online.
SHAFT AND BEARING
