Hi guys I just had my drive presure tested and a bad seal fixed and boat was put back in water. I now notice a new faint wistling noise. when at planning speed it sounds like wind blowing through lines the noise is faint but I can here the noise slow with engine in nutral I can just sort of hear it. Boat seems to drive great and my oil problem has now been fixed. But I would like to know what this noise is.
Things I just recently had done over winter drive aligned, coupler checked and looked good, replaced u-joint assembly, replaced gimbal bearing, bellows and manifolds. I did all the above as preventitive mantnance.
