Ive had this problem for 3 seasons. Just some background. 4 years ago I had the engine replaced with a brand new long block. I have twin Mercrusier engines on my 1997 Cruisers Yacht. One engine was replaced with new longblock. I assume the heads were simply put on from the blown engine. I also had replacement risers and manifolds which I purchased from Boatfix. When I fire up the engine it's hydrolocked. It seems that water enters 1-2 cylinders. If you're facing the engine its the left hand side first and second cylinder, thats were the water comes in.
Last year I took the riser and manifold off and replaced the gaskets, that I thought did the trick. I used it all season with no problem.
Fall I winterized the engines as always. Now the spring comes and I did all the things that needed to be done, waxing, gear oil etc.
Im going in tomorrow Saturday and of course the problem. I took all the plugs and let the 2 cylinders drain (not a lot of water) shot WD40.
My question is any ideas from you folks on what might be causing this?
