Volvo 5.0L I/O which will show no sign of overheating until you exceed 2000 rpm. At that point it will jump to 180++ or higher. Freshwater flushing valve replaced, connections tightened, and thermostat replaced. No change with the problem. Also removed and checked the waterpump impeller (brand new in May 2006) and found no problem with it.
Risers and manifolds checked and replaced (8 years old) still no improvement. Thermostat removed and still no improvement - seems to be some sort of problem with insufficient water volume getting to the engine.
Looking for suggestions and/or comments to solve the problem. Boat is 8 years old, used in saltwater, kept on a lift and freshwater flushed after each use. Engine hours show 350 hours over 8 years.
Mechanic is now suggesting pulling the boat, dropping the lower unit and checking for some obstructions in the water line.
