Hi all.
My previous engine (1997 Merc 5.7) had a mechanical fuel filter sitting between the fuel filter and carb line in. The line between the carb and the pump is a form fitted stainless steel tube.
My new 5.7l uses an electric pump. A few questions....is it CG compliant to use a black flexible fuel approved line in place of the steel tube? The electric pump sent with the engine has barbed brass connectors so I don't think I can use the steel tube.
Anybody else have to go from mechanical to electric? If so, where did you mount it and how?
