Teak
fishingfever
The teak in the cockpit on my 1985 39 Sea Ray Sedan is turning dark like is has mold in it. In June I had sanded all the teak nice and smooth, then oiled and have it kept oiled all summer. Is there any help for it.
Teak has natural oils, which help to preserve the wood. When you sand it, it removes equal layers of hard and soft fibers and will be smooth, but you have thined the boards, and eventually the plugs will wear thin and come out, exposing the screw heads. When you add artificial oils, they will attract air pollutants, dirt, molds etc and become very dark. If you "clean" teak, by using harsh chemicals--mild would be oxylic acid--harsher would be either a strong acid followed by a base or a strong base, followed by a weak acid. Both of the latter chemical tend to damage the wood surface. The softer wood is taken out, especially if you power wash or use a stiff brush with the grain.
When I have had to clean teak, I have used oxylic acid, followed by TSP--this is as harsh as I like to go--use a green scotch pad across the grain--but this will cause some wood damage. The "blander" way is to use "whisk" and dilute chlorox--but this will often not remove any of the dark material.
Frankly the teak decks are best washed peroidically with salt water and brushed across the grain with a flexiable brush or the scotch pad. Then just let nature take its course. The oils look fine for a short time. There are compounds like "teak Guard", or Semco which do seal the teak--and the latter is available with some pigment in it--which keeps a lighter color.
When I/we had teak on our boats, we would clean with 50/50 ammonia & water. If we wanted to lighten, we would use 50/50 liquid bleach & water. We would either leave natural or let dry & use oil of choice. Did it that way for the 6 years I owned that boat.
NO TEAK NOW !! YEA !!
Had the pleasure *NOT* of stripping all the bristol finish off my teak last summer. Used TSP mixed with Clorox and warm water and a green scotch pad and rinsed well. The TSP/Clorox mixture worked very well and after it dried the wood was absolutely beautiful. Unfortunately, it does not stay that way. After some research I decided on 3 coats of Armada satin. Armada doesn't have that deep orange hue of Sickkens and I'm very happy with the outcome. Originally I considered teak oil, but as mentioned above that's more frequent maintenance and still turns dark. I really don't like the natural silver look either, but some folks love it.
Yes, get the "3-part" teak kit, I think it's from Starbrite, cleaner, "BRIGHTENER", and oil.
Grady - the 2-part cleaners have an harsh acid that has tendency to raise the grain on the softer fibers. This forces heavier sanding and an uneven fishing. When used repeatedly the long term effect is the wood thins out and becomes bumpy (the grain). It usually evident on the teak of older boats. The use of various mixtures not so harsh used on this thread tend not to have that effect.
Using oil is the problem. It just attracts dirt and mold. Either just keep it clean and let it go silver/grey or use something like Cetol to seal and finish it with. Cetol/Armada last about the longest and are the easiest finishes to use. Just be sure to sand the wood nice and smooth and use at least 6 coats and not the 3 recommended on the can.
Like Bob said, clean it with oxylic acid for a mild cleaning. But I would not follow up with the TSP as TSP tends to darken the wood IMO.
You can make your own two part cleaner.
Just mix 1 cup TSP and 1-3 cups ammonia with 3-4 gallons of fresh water. That is your #1.
Wet the teak and scrub with the #1. Keep teak and surrounding areas wet but do NOT wash off #1.
Mix 2-3 cups muratic acid with 3-4 gallons fresh water. That is your #2.
Spread the #2 on to the teak and lightly scrub. The teak will go blond. Be sure to get the #2 on all the teak that has been scrubbed with the #1. After you have lightly scrubbed down all the teak with the #2 rinse everything off very, very well.
Since you mix this yourself you can delute it down to any strength you wish and it costs about one tenth or less of the permixed kits.
It should go without saying you should use hand, eye and body protection when using this or any other harsh cleaner. And it should not be used to clean the teak on a regular basis.
I personally like the Semco products. They are not shiny and give IMPO a more natural look. It comes in a few colors though natural is my fave. I start by aggressively cleaning with soft brush across grain and ox acid and tsb followed by a good rinse and dry in sunlight. I then put the Semco on in thin coats until I have 5 coats on. Very easy maintenance and annual recoat and always looks good and fresh.
I'm in the process of refinishing all the teak in my boat (the entire interior is teak). Stripping whatever was on before has been a nightmare, but we've decided to go with the Epifanes varnish. They seem to have the best reputation for quality and the final look of their finish is fantastic.
After you've sanded to bare wood, you'll need to clean the wood to get rid of the black marks. There are 1 and 2 part teak cleaners available, but if it's really bad, the 2 parts are a better choice. I prefer the Aurora 2 part over many others (especially Starbrite) as it's much stronger.
Another option is straight Oxalic acid, which is what I use. Mix the powder with HOT water and scrub it in. Rinse with Vinegar to neutralize it, then lightly sand the grains that have been raised. Oxalic acid it the best way to go for large areas. The Aurora 2 part works well also, but you really have to rinse it with water, and watch getting any of the stuff on gelcoat or anything else - it stains.
Ended up doing 6 as you suggest, and then a maintenance coat each spring. Been two seasons now and it's holding up very well.
