Thru hull transducer Regal 2960
Blum587
Hello all,
I am replacing my thru hull which is located just forward of my starboard engine. Does anyone know what angle I need? That is my main question.
I have an 1.5 inch hole and will hook it up via Nema200 network. Any recommendations? Thanks in advance!
Bart
Originally posted by Blum587
Also, would mine have a cored hull, or solid?
That w/b a great question to boat mfg!
BOB J
BOB J
If you've got the time, out of the water, just measure the old one with a cheap protractor.
Thanks for the replies. I ended up findin it to be a cored hull, opening it up to a 2 inch hole (bigger on the inside layers), and made an epoxy cavity to seal it between the layers. Then installed a garmin intelliducer, and putting it on my NEMA2000 network. Works great
