It's not all about hoping to recoup the investment through fuel savings , though over time a lot of us have done that even with the high-end F/S models.
Don't neglect to also factor in the great personal value of having a very accurate totalizer display of Gallons Used ( after calibration ), as well as the ease of comparing present fuel flow ( or NMPG economy ) to normal or between engines to help notice or confirm suspicion one engine is a little "off" for some reason that would then more strongly support further investigation
For me, the 9000 series was the only real choice because the dynamic NMPG readout in changing conditions is way more valuable than just viewing GPH, but RWS you may prefer not to swap out a tach in your integrated diesel engine dash panel. I really like the easily readable & colorful, backlit, accurate, digital tach in the 9000's vs the original analog tachs they replaced in the same holes.
As a somewhat interesting related note, by checking the F/S's when trimming the tabs I found I oddly get slightly better economy with a very small trim lean to port, and that when the tabs are very close to optimum for any given planing rpm, only about a 1/2 second tap on the Bennett tab switches can be proven to slightly add'ly increase economy via the F/S NMPG display.
Do you or I really NEED these tools. Not really, ....but they do provide appreciable value.
