trawler???
I own a 1989 30ft carver now and was thinking of switching to a trawler style boat. Any imput on this change would be greatly app....
What do you want to know? What type of information. What is your budget--what are your goals? Your question is too broad. There are lists devoted to trawlers and the lifestyle of living aboard. (which is an entirely different subject).
No doubt you mean a slow, low powered boat as most boats sold as trawlers are simply that. Nothing wrong, just don't expect trawler sea keeping from a semi planing hull. Even those beautiful grand banks boats are not true trawlers but they are very nice nevertheless.
Also realize that many high HP diesel boats produce similar fuel use as those "trawlers" when run at the same speed. Since boats with more powerful engines are heavy on the market these days good boats not called "trawler" with the economy you are probably seeking may be cheaper than something called a trawler that may have higher demand these days. e.g. my 44 ACMY at 38,000 lbs yields 2+ nmpg at 8 kts and more at 7kts, it will also do 23kts at the expense of a lot more fuel.
what do you need to know? depends what size trawler youre looking at, what type of trawler, and how you're going to use it....
Originally posted by livingaboardboy
Boy this is going to be fun....
Twins or Single,
Teal decks or no teak deck,
Sundeck, Europa or Traditional,
Pilot house or flybridge,
and my favorite....
Galley up or galley down.
But really, your intended use and needs will dictate what type your SO approves of. There are more issues to enjoy while you hunt. Such as double cabin, walk around queen and then there is the size of vessel. Don't be confused with the variety of boats today that are so called 'trawlers'. A true trawler will have an extended cruising range at a low speed. A true trawler may not be bluewater quality as in an equal size sailboat. This is where one has to trust their judgement in reading the weather and picking the right window of opportunity to make that crossing.
Keep us posted,
El Sea,
1976' Thompson 44
Suite 44
St Petersburg, Fl
"...Teal decks or no teak deck,..."
I don't ever think I have seen a trawler with teal decks. Doesn't mean they don't exist, just that I have never seen one. ;)
There really is no problem in running slightly above idle for extended periods of time on a boat with twin gas?
I always assumed you may run into issues, like carbon buildup or running a generator with no/little load, etc.
Well the original poster has not re-appeared....but gas engines do fine at continous low speed--and so do most diesels as long as you keep them up to operating temp, and every hour or so, spool up the turbo charger (if so equipt). I had many thousands of hours on Perkins and Ford Lehmans at 1300 RPM with zero problems.
Many of the Taiwan trawlers (and others) came with teak decks. Unfortunately often the deck structure below this was not well sealed, the teak was not properly bedded, screws worked loose, owners scrubbed or sanded off the bungs over the screws--and water intruded into the plywood--or Mystery Wood--core of the deck. Then rot and a major problem rebuilding the decks.
I personally don't consider a boat which will do planing speed a trawler--traditionally the trawler was derived from fishing boats--were displacement or maybe semi displacement hulls, and traveled at slow speeds. More recently the "fast trawler"--probably more like a motor yacht--have been in vogue. Many of the boats called trawlers are hard chine, with fairly flat bottoms and if you put enough HP in them, they would plane. "Voyaging under Power", a book originall by Bebee and more recently by Jim Leishman (Nordhavn Yachts)--has multiple graphs of HP/speed/range or fuel consumption. The more effecient vessels were at 6 to 7 knots, had rounded hulls, and relitatively narrow beam.
