It's a Mercruiser alpha 1, Gen 2. The trim/tilt raises and lowers the drive just fine, but it makes a creaking sound both ways. Kinda like a hinge that needs oiling. Any ideas?
If I have to make more video "How to`s" for installing the missing grease fitting ,I`ll start drinking again or be making a lot of money with mobile installs
Get someone to raise and lower while you listen to exactly where the squeek is coming from. If it's from the ends of the rams, loosen them and put on some grease to the pins.
