Vacuum Generator
kbeachy46
I have a vintage 2001 Vacuflush System with Vacuum Generator VG 12, 759012. Waste was accumulating on top of the bellows so I pulled out my manual and see the bellows is part number 230980. A late night trip to West Marine and I pick up a a Sealand bellows Mfg No 385230980 (Kit, Bellows-S/T Pump). West Marine says this will work and has all the parts I need. Long story short, it doesn't work. It is as though the rod portion of the bellows is too short. With the 2 piece Bellows Clamp installed the bellows will not allow full movement to top of the upward stroke. The motor turns a partial revolution and stops and the circuit breaker trips just as it should when jammed. Thinking maybe there was a re-design I even tried installing it without the 2 piece clamp to allow more movement upward. Since the bellows would not seat correctly on the O-ring I canned this idea. Are there 2 different bellows kits? Old one 230980, newer version 385230980? Any thoughts appreciated.
