- Nov 4, 2006
- 24150
- 1,309
Drained my outdrives last year and had no issue with the drained fluid. I did however have to heat one of the forward props to get it off. My guess is that I damaged the prop seal because the fluid was milky when I drained it this year. I also did not replace the o ring on the drain plug or the dip stick, which I probably should have.
My question is how big of a job is the prop to replace? Do I need a special tool or am I better off letting my mechanic do it? Also I am assuming I need to flush out the outdrive with something to remove the water. What should I use for that?
