Volvo to Mercruiser raw water pump conversion
Because after 2 volvo leakers and a different companys leaker and knowing
I service 2 28 Wellcraft Coastal with these pumps that are 28 years old, got to be better than a volvo.
Finally Complete, all spacers will be machined from 3/4 round stock , 1 inch hose couplings/joiners/ splice .(3) , 6 hose clamps,
Dayco hose 71596 , original thermostat hose to pump is reversed and given a slight twist to join. From the original raw water inlet hose at the pump cut off the 1 1/4 end so its 3 inches long and save, (pic 1)cut off the 90 deg bend and discard, shorten the raw water inlet hose at #6 spark plug by removing 8 1/4 inches, and use hose splice to join and clamp.Install and clamp Dayco hose , install original thermostat hose reversed and join to Dayco hose with joiner/splice and clamp. Not shown is a ty-wrap holding the Dayco hose in place.,5th pic.
raw water pump pully alum 52822T, steel 73798A1, engine mounted pully 90081T1, pump bracket 89535T
Hope you have better luck than I did. Both my original merc pumps leaked at the shaft. One damaged the belt because the shaft slid out. Replaced them with Sierra pumps and both of them leaked.
I don't know. Everything was installed by a professional tech. I doubt that the belt was so tight it ruined the lip seal. It didn't leak for a few years.
