I have a 2006 Regal 2400 bowrider with a Volvo 5.0 GXI duoprop.This is my second season, I have the boat kept under a high & dry arrangement. The yard was recommended by the salesmen form the Regal dealer. I use the boat on average once a weekend, the season is from 5/15/-10/15. I went to use the boat today and when I got to the yard I was told that the trim pump was blowing the fuse and wouldn't work.
About a month ago the starter had to be replaced.Last year,one riser was running hot causing the alarm to go off, it turned out to have a rod in one of the passageways creating blockage,(mfg defect), the ignition switch and throttle cable also had to be replaced.I though last year's problems where just first yr problems, but this year I am wondering if this is normal wear.I am a first time boat owner, all the problems have been under warranty,
should I expect more?
