Windlass question
jodon2.
From the description it is not freefall from the helm.
Al
A completely on-deck windlass, the Genius 600 is easy to install, with just four simple fasteners. Clutch handle releases the gypsy for manual free fall.
"Dual Direction Solenoid" is noted in description. Seems to not be a free fall.
My personal preference is power down as less chance of dumping rode on top of anchor
Good luck.
Ron
Apologies for the hijack, but what is preferred among windlass operators: freefall or power down?
I use freefall, I have the option of powering down but never use it.
power... if for some reason i need to stop the windlass as the anchor and chain is on the way down, I can do it right away without worrying about damaging the windlass.
maybe it's not an issue with a small anchor and line, but i cant' imagine the stress on the WL if you suddenly stop a 50 or 60lbs anchor and all chain.
not sure i really see the benefits of free fall. speed obviously? but if i need to anchor in deep water and paying 200 or 300' will take too long, i can still jsut go to the bow, pull the chain off the gypsy and put it on the rope capstan to free fall.
Pascal, most of us with a windlass do not have that option. Plus, if you have a reasonably small cruiser or convertible (less than 35') & you are trying to anchor in a particular spot, 70' per minute power down can be a long time. Our boats don't weigh 25 tons & we don't have a 5' draft.
I've had both types & I prefer freefall. The one thing I would suggest is to upsize to the next larger windlass class & larger ground tackle.
Al
as always, it's matter of preference and how you use the boat...
not sure what displacement or draft has to do with a windlass... if you don't draw much, you are actually more likely to anchor in shallow waters with less rode, so speed doesn't matter much.
one or two minute to deploy doens't make much of a difference. what makes a BIF difference is having remote switch at the helm to control the boat...
Great displacement & large draft mean you are not being immediately pushed
around by any wind. That can make a great difference when you are trying to
anchor over a particular spot.
Agree on the helm control. I do think I will also add in either bow control
or the Lewmar remote control.
Al
For us, when I am fishing we need something that will drop the anchor immediately so that once I have adjusted for wind and current, the boat will drift back over the structure in which I plan to fish.
I was out on another captain's boat the other day and anchoring over the structure took several tries because the windless would not enter free fall mode, however, if you are not fishing, I am not sure it would make a difference.
-Michael
If the windlass is mounted correctly it's no big deal to let it free fall. They are made to free fall after all.
We do it with anchors weighing a couple of hundered pounds all the time. And you don't have to suddenly stop it. You can slow it a bit first if you want to.
Normally you are just stopping the chain from free falling after the anchor has hit the bottom. So the windlass is not suddenly taking on the full load of the chain and anchor.
"i can still jsut go to the bow, pull the chain off the gypsy and put it on the rope capstan to free fall.'
But not everybody can do that. If it's a vertical windlass or a horizontal one that has the wildcat on one side and the capstan on the other, you're out of luck.
even on smaller boats, if you are pointing into the wind when anchoring, you're not going to get blown around and again, if you have remote switches at the helm you can keep the boat exacly where you want it to be. I dont' fish, but i often anchor in crowded anchorages where the anchor has to be in a very precise spot (by a few ft) and i dont' find power down to be a problem at all.
I prefer to set the anchor in the wind and don't let the anchor free fall. I point the boat into the wind and can let out the rode on the bow. The wind will push the boat back and most times also set the anchor so I don't have to have someone else backing up the boat. This does take a few minutes but I am rarely in a hurry to do anything when I am on the boat.
Free Fall! When we raft up in the cove it's always the boats with freefall anchors that drop anchor - they're just so much easier to deploy.
I can't think of any time I've ever wanted to stop the descent prior to hitting bottom.
