- Feb 26, 2006
- 20354
- 1,075
With the 2008 boating season about to get into full swing, everyone is thinking about oil changes, tune up's, stocking the fridge, the wine and beer coolers, but what about your electrical system? Have you given any thought to the maintenance or preventative maintenance of your boats electrical system? If not you should, and you should prior to your first launch.
Corrosion affects all boats, but those in salt water are more susceptible, and should be checked more frequently. The size of the boat does not matter either, if it has any type electrical system. A fire can be caused from a bad connection on a trolling motor.
Your shore power cord is the first part to address. Check both ends, look for corrosion on the prongs. If you are able to disassemble the cord ends, take those apart, check for corrosion, check for loose connections, and give the screws a check with a screwdriver to make sure they are tight. Check the back side of the plug on your boat for the same things. If you see something that just does not look right, either replace it, or have a qualified electrician check it out for you.
If you have a generator, check the cords or connections to it for the same things. Make sure all connections are tight and clean. Make sure the ground wire is clean and free of corrosion, and has a good tight fit on both ends, the ground could be your lifeline in the event of a malfunction.
If you have an inverter, the same procedures apply, but, pay close attention to your 12vdc side. There is a tremendous amount of current draw on the 12vdc side, and anything that is preventing a good, clean, tight connection is asking for a fire.
From there, occasionally, it is good to remove your boats breaker panel cover, and check there as well. Make sure all screws to the breakers and the buss bars are still tight. They WILL loosen over time due to the heating and cooling. Also look for signs of corrosion or heat. Any place you find some is the potential for a fire. If you do not feel comfortable doing this type of work, consult a qualified electrician to repair it for you.
Your boats 12vdc system is also important, you boat can run with out 110 or 220vac, but can't with out 12vdc ( most boats ). Battery connections should be clean and free from corrosion. There are several products and methods available to prevent corrosion build up on battery terminals, and will greatly extend the life of your cables. Connections from the batteries to the 12vdc systems on your boat should be checked. The same things apply there as do the 110vac systems. Check alternator and starter connections as well.
Safety
Just a few words on safety. Electrical systems are dangerous. Serious injury or death can occur, and occur very quickly. When you service your system, make sure all sources of power are disconnected, and placed in a state that they can not be accidentally turned on while you are doing the work, you should ALWAYS test for voltage before touching anything, even if you know it is off, check it anyway. You don't need to have a 500.00 meter for this, you just need something that works.
Another point is the 12vdc side. Most people don't realize that the low voltage side of your system can kill also. Did you know that when a starter is engaged, there can literally be hundreds of amps being drawn from the batteries? It takes only milliamps to kill, the voltage does not matter, it is the amps. Some inverters draw massive amounts of amps while they are running, touch the wrong thing, and it could be the last thing you touch. Use caution and common sense when ever you work with any kind of voltage or power supply system.
Again, if you don't feel comfortable, or are not sure, ask a qualified electrician for advice or to do the work for you. The small amount of money this will cost you pales in comparison to an injury or death, or to an on board fire caused by a preventable issue with your electrical system.
Have fun, and enjoy the season!!!!!........D....
Safety
