1984bayliner
- Mar 8, 2006
- 20454
- 3
Hello gentlemen,
Need your help if you would be so kind. I own a force outboard on a bayliner bass boat with a tilt problem. If I try to tilt the motor under power it will not operate. I can raise the motor while not under power but it will leak down in a short amount of time. Is this the way it is designed to work or do I have a problem as there is no trim only tilt? If repair is in order it must be related to the hydralics. I need a source for repair parts like seals and gaskets etc. Thanks in advance for you help.
