I have owned a 1993 Carver 390 Aft Cabin for 12 months; it's a great boat. The only problem that I cannot resolve is that the tachometers work only intermittently. Usually only the starboard tachometer is working, but at other times the port one works. Sometimes both work for a while and occasionally neither of them works! The "Sync" display dial follows the tachometers (hard over when one works, accurate when both work).
An electronics guy who has looked at the problem says that the tachometers are driven from the alternators. He suspects that since both port and starboard appear to charge whichever battery set is selected (1 or 2), the tachometer problem may be linked to the alternators "fighting" over which one whould be charging.
Does anyone know of this problem and the solution to it? Can anyone suggest further diagnostics to get to the root cause?
Many thanks!
Many thanks!
