1999 Searay 230 Overnighter Signature Select
1999 5.7 Mercruiser 5.7 with an Alpha I Gen II outdrive. Motor and drive are immaculate. Motor was recently serviced, new gear lube, new oil and filters, new filters, new plugs and wires. New short shift cables, new boots, bellows, and gimbal bearing. Motor is turnkey.
New Garmin 742 GPS – Chart plotter with touch screen. Lowrance fish finder and built in depth sounder. VHF and new 8ft Shakespeare antenna. AM-FM stereo (I never used it).
Cuddy cabin is dry, no known leaks. Has a port-a-potty that I never used. Cabin upholstery is clean, though one cushion has a rip in the material. Headliner is in excellent shape.
Cockpit- upholstery is original and in very nice shape, clean, and no stains. Has a built in sink and cooler, 8 gallon fresh water tank, has transom shower (no hose).
Boat has two batteries, with on off switch with options for 1-2 or all. Has a new attwood bilge blower and new automatic bilge pump, which is wired for the boat to sit in the water, so when the battery switch is off, the bilge pump will still pump.
Boat comes with a full cockpit cover, bimini top, full camper back cover with screens and isinglass, and a full winter cover.
Trailer is brand new 200 miles on the Venture Commander 5300. Dual torsion axles with brakes on BOTH axles. LED lights, aluminum I-beam, trailer has matching spare tire. I replaced the bow stop with a yellow non marking bow stop.
I have tons of pictures and videos of the boat, if anyone is interested, feel free to give me a call on my 516-287-4236. Boat is located in Myrtle Beach SC
