iam looking at a 02 260 w/ 6.1 brovo 3
hows the power withthe 6.1
also the trayler has disc with serge brakes
do these work in reverse
can they be converted to electric?
If you are referring to the Merc 6.2, you will be fine. It produces 320 HP. It is a high reving engine meant to cruise around 38 - 4100 RPM's. Accordingly it will be noisier than the 7.4. However if the engine room is properly insulated you will be OK. The 6.2 weighs 202+ pounds less than the 7.4. Better fuel economy and you are not hauling around the = of another human in the boat.
