3 miles out in the ocean is another LEGAL choice ....
depending on when u go back in u may still have an issue ... and there might be no bouys for a plan B
I think there all shut down for the winter.......but call this guy......he's mobile....he'll come to your boat and pump you out....by Land or by Sea
Fire Island Pump Out....631-645-8356
Another option would be to go down Don's canal and dump you tank there, works for me ;)
Don't know for sure, but last year Guy Lombardo Marina's pump out was up and running at this time, on Hudson Canal, Freeport. There are plenty of boats still in at the marina (looking at it right now), but I'll double check tonight for you.
Babylon Fishing Station is probably still open also. They are down the canal by the Babylon Village docks. $5 for a pumpout.
I once heard that Captree stayed open late or all year, but can't verify that personally. It's nto exactly convenient to go over there.
With mine, when I've had some left in there, I dump in the no-tox, but not the pink. Use the blue or green or whatever it is, the -100 stuff. (WM in West Islip still had some this past weekend.) It's more concentrated so, when its diluted by the waste in the tank, you will get a lower freezing point than the pink would give you. At least, that's the way I figure it. I haven't had any problems with my tank freezing.
I don't see this as a problem from a disposal/environment perspective, since it is considered non-toxic, and it's going to the treatment plant once you get it pumped out next year anyway.
