No worries if it's in the water. If our temp gets much below the 32 or so we're expecting along the St Johns and ICW, I set the boat back into the water from the boat lift. That works with the water temp down in the 50's.
I was just outside. Thermometer on the fence, away from heat sources, showed 28. Inside our RV, 35 and its exterior temp showed 31. No thermo's down by the boat, but the dock hose was not frozen. I'd say we were OK...
