30 Amp Male adapter with a 110 Female Y
Radiowaves
It this adapter type available ? I am looking to plug in as normal with my 30 amp and also run an appliance from a dock electric box. I do have a 30A Male/110 Female small mini adaptor that I used last weekend. But that was ok since I had an extra outlet since no one was right next to me. So I am looking for a Y adapter.
I can run an extension from my cockpit but rather not.
You could use a reguler 30A Y adapter and then use a 30A to 15A on one of the Y's
Niles
Niles
Yes then I could ust that mini adapter that I have been using. Thanks.
Brad.........if you have an old Y.....cut off the 2-30V's and wire in 2-115V's.......its easy
When I wrote 110 in the start of my post, it is really a 15A/115 not 110 ? Looking for a normal house plug type for a Crock Pot, Griddle, Portable ice maker etc. that I can use on the dock instead of on the boat. I think what Niles mentioned would work with my mini hard adapter. I use it for an Ice Eater, plugged in an empty 30A then to the Ice eater. But it would be nice to have a Y with a 30A and a 15A115V ?
