does any body know how to remove the side windows ican only find one screw at the bottom to stop them from sliding but cant lift them high enough to take them out
On my c/c I must remove the entire wondow and drill two pop rivets out in ordre to spread the window frame apart just enought to remove the window . To reinstall just reverse the proceedure. IMHO terry-----tboss
What year Silverton? I have a 1986 34C and removed all the side windows two years ago to have them tinted limo black. The fly bridge has a tendency to sag a little after many years. If you Silverton is of this year or close let me know and I will tell you more how I removed my windows.
if you have bypass double track sliding windows look for rubber blocks on the top or bottom. remove those and there is enough room to lift the glass out unless there is some sag. Then use a bottle jack to spread the frame silghtly.
