My new to me 98 355 ACMY sanitation system came factory installed with a vac u flush and overboard discharge system. In familiarizing myself with the boat I noticed the Y valve handle that ports waste from the two holding tanks to the overboard maceration pump is pointing in the direction of the line that leads to the aft holding tank. I cannot reach this Y valve (at 6'3" I'm too big) and I'm assuming with the handle in that position, the pump dumps the aft waste holding tank. I cannot see any writing on the valve or handle. Is my assumption correct?
Does the Y valve have an OFF position that suffices for the CG requirement that the overboard discharge be disabled? If not, will removing the handle of the sea cock with the valve closed, comply with all CG requirements?
