3880 Fresh Water Leak behind bathroom shower
eddinardo
Rommer. Do you know how to get access to the fresh water hoses behind the shower. I'm pretty sure I have a leak there. I'm not sure how to access that area.
Ed
Ed,
The mirror has double sided tape on it and can be easily removed, then remove shower body cover.
Have you eliminitated the fittings under the sink.
What are the symptoms to suggest a leak behind the shower?
Thanks Rommer. I thought that was the case but I didn't want to break the mirror. I guess I should heat it up with the hair dryer. I did eliminate the faucet which I accessed after dismantling the cabin under the sink. I'm pretty sure it's the shower because I took apart part of the 2nd stateroom closet and could reach my head back to observe the wetness but I am guessing. Sorry for taking so long to reply to your question.
Ed
Ed,
This is Gary, not Rommer.
Is the water pump cycling? If not, the leak could be from a few different sources, windows on port side, water getting thru rub rail just to name a few. Good luck and keep me updated.
Sorry Gary,
I replaced my water pump about 2 years ago and it is extremely quiet. I really noticed it when I leave the freshwater switch on for a day or so. I'll keep you updated.
Thanks again Gary
Just wanted to say thanks for the undeserved thanks but also wanted to point out that Gary is a tremendous source of knowledge and information.
