W E L L L L, DR confirmed it, have a broke rib and a seperated collar bone, oh joy what fun this is!
I have taken both risers off, soaked in CLR, had one of them ground due to some water intrusion into the manafold. They were not blocked though. There was some of the same white rock sitting on top of the gaskets, but really not that much.
I have pressure tested the closed side and it holds pressure, no leaks either.
But, I did find something on the oil cooler while I was down there, the outlet clamp was not tight, really not tight, like slid down the hose not tight, and I did fix that. Not sure if I was sucking air or not, but no leaks while sitting, in fact the bilge stays dry after being in the water for a few weeks.
Shop vac got most of the oil out, but I do have some pigs in there for the rest of it.
I had the admiral start the engine up while I was in there and I did not hear any thing unusual, but, I did not run it but a few seconds while I pined the leak down, so not sure yet if there is damage or not, I feel not as it started and ran too good, with out any unusual noises.
I have not pulled the raw water hose off, but flow from the out drive looks really good. I am really leaning towards the engine just likes to be at 200, which is really not that hot. My 4.3 vortech runs at 210, and that is normal for it.......D........
