- Oct 23, 2013
- 33487
- 242
2005 496 Merc(8.1)
At idle, cruise, acceleration at random times the engine will die for a moment. At cruise it will go down 200-300 rpm's then go back to normal. At the same time I will get a 1 second long alarm. The rpm read out, oil pressure read out, engine temp read out all go blank. Engine runs fine except at random times does this.
I wiggled all wiring harness connections. I checked contact on ignition key and tach. All battery terminals are clean.
Could it be a dirty flame arrestor?
IAC sensor?
Crank position Sensor
Fuel filter was just changed
Fuel is fresh
Any thoughts?
IAC sensor?
Fuel is fresh
Any thoughts?
