Charlie, why would the heat affect the Coil? When you say that TB ignition runs directly off the Battery is there a seperate feed? Because....I did replace the house bank earlier in the season, there was a wire running to the positive terminal. The end point ring was worn and broke, I assumed that it was the bilge pump and just trapped the wire. Since the bilge has been working I have not thought about it...If that is in fact the ignition wire it may be losing contact.
