odd looking critter...
it's got side decks so you can walk around. At least on this one you can get off from the side unlike others. take a look at some of the carvers, there is 396 down the dock from me, you can not get on the dock unless you go down the swim platform, or you do acrobatics and climb over the railings.
30k is cheap but you can quickly rack up 20 or 30k in repairs... engines look pretty clean although the engine mounts look real rusty. Now on second look, it looks to me that someone covered up the engines with spray paint, look at the overspray on the hoses and the model label. Does crusader usually paint the carb bodies or have the carb been replaced ? the paint stops halfway some of the fittings and levers.
usually, before getting a survey, i'd want to get a sea trial done to see if it's even worth surveying. now the problem is that due to the low price, if the engines dont' even start and dont' run well enough to leave the slip the seller will not be willing to do anything...
worst case scenario... a pair of long blocks ? 10k ? some canvas work, 5k? new engine controls and cables, 1k? a new genny, 6k?
might not be a bad deal if the hulls checks out especially if you can do some of the work yourself. Now if you have to pay $90/hr yard rate to replace control cables, clean and wax the boat, then it will add up and indeed you may as well get a "good" one.
before spending money on the survey, look at it closely. check for leaks around the windows, make sure those odd shaped windows aren't cracked... they must be $$$$. Poke around, make sure there are no cracks, rot or delamination around the stringers and bulkhead.
also, check how hard it is to get the engines and genny off this boat, will they fit thru the aft door? probably but make sure.
is there a ladder to get to the FB from the saloon or do you have to go out the sides and around ? and what's at the stern ? why no windows on each side of the stairs ?
odd design, but hey... if the Mariner sells... why not this !
