I'm trying to find some info on my 56gal fuel tank. The fuel outlet hose attaches to a 3/8in. barbed ftting on top of the fuel tank. I believe this is supposed to be the anti syphon valve but it is not. I removed the fitting, then removed the block style 90degree fitting into which the barbed nipple fitting screws into. This 90deg block fitting has a tube attached to it which I assume is the fuel pickup tube which is not removable (no space between tank and deck)
Does anyone know if this fuel tank is supposed to have an anti syphon valve on it and if so where and what type???
Thanks for any help.
Randy
Randy
