The 2 gauges on the right(volts & fuel) don't light up. Is there just a bulb to replace or is the light built in to the gauge? If so where can I get the bulb?
You can go to your local auto parts store and purchase little lights Part # 161. You have to remove the dash and they have a little plastic twist that they sit in. You may also be able to reach them from the access panel in the bathroom, but remember to close the cabin door.
